Freeze on startup
Posted: 29 Apr 2010 22:35
I'm a new HELI-X user, running Ubuntu 9.10. When I run runHELI-X64.sh, I get a dialog asking me my language preference. After I click that dialog, it disappears. I am left with the splash screen, and a progress bar that is 10-20% complete. There is no further output. I must CTRL-C to kill the program.
Console output is:
The contents of files/log.txt is:
The values of LIBS and CP, at the time java starts, are These look correct to me.
I get the same output whether I use the Sun JRE or the OpenJDK JRE.
Have I misconfigured the system in some way? Is there a known bug that would explain this behavior?
Console output is:
Couldn't find tag "WindowSettings" in file "/home/don/HELI-X/files/Application/ApplicationSettings.xml"
Couldn't find tag "InfoWindow" in file "/home/don/HELI-X/files/Application/ApplicationSettings.xml"
Couldn't find tag "ChatWindow" in file "/home/don/HELI-X/files/Application/ApplicationSettings.xml"
Set new path for the resources: /home/don/HELI-X/resources/
Set new path for the user files: /home/don/HELI-X/files/
Found 27 display modes
Controller found: Name: WAILLY PPM(WAILLY PPM)
Using Stick WAILLY PPM
Digital component found:Thumb
Digital component found:Top
Digital component found:Top 2
Digital component found:Pinkie
Digital component found:Base
Digital component found:Base 2
Digital component found:Base 3
Digital component found:Base 4
Digital component found:Base 5
Digital component found:Base 6
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
Analog component found:rz
Digital component found:pov
Controller configuration file not found: /home/don/HELI-X/files/controller/WAILLYPPM.xml
SoundDriver could not initialized
Sound Driver could not be initialized. OpenAL is missing?
LIBS=:/home/don/HELI-X/libs//jogl/linux-amd64/:/home/don/HELI-X/libs//lwjgl/linux-amd64/:/home/don/HELI-X/libs//joal/linux-amd64/:/home/don/HELI-X/libs//gluegen/linux-amd64/:/home/don/HELI-X/libs//jinput/linux-amd64/
CP=:/home/don/HELI-X/libs/HeliX/HeliX.jar:/home/don/HELI-X/libs/gluegen/gluegen-rt.jar:/home/don/HELI-X/libs/jagatoo/jagatoo.jar:/home/don/HELI-X/libs/javagamenetworking/jgn.jar:/home/don/HELI-X/libs/jdom/jdom.jar:/home/don/HELI-X/libs/joal/joal.jar:/home/don/HELI-X/libs/jogl/jogl.jar:/home/don/HELI-X/libs/lwjgl/lwjgl.jar:/home/don/HELI-X/libs/jinput/jinput.jar:/home/don/HELI-X/libs/math/openmali.jar:/home/don/HELI-X/libs/xith/xith3d.jar:/home/don/HELI-X/libs/xith/hud-themes.jarI get the same output whether I use the Sun JRE or the OpenJDK JRE.
