No controller found
Matajen
No controller found
Post by Matajen »
I have had Heli-X for a long time, but didn't use it for a couple of years. Now I have downloaded version 6. I have a JR Propo radio with a cable from DSC to USB (that I used before). My computer is an iMac with latest Yosemite OS. Heli-X does not recognise my transmitter. I just get the message "No controller found". Any advise, please?
Matajen
Re: No controller found
Post by Matajen »
Now it doesn't say "No controller found". However, when I go in to configuration the sticks won't move the bars and it says "No channels found". Any tips?
please check if your interface does transfer the data from the transmitter (in the operating system (Joystick tester)
Matajen
Post by Matajen »
I plugged it in and out a couple of times and now it works! Strangely it worked when I connected the controller after I started the program, i.e. contrary to the instruction. But it works! Thanks.
Coolio
Post by Coolio »
I'm in the same boat, I have El Capitan OS and an E Sky 4 Channel controller and it has only worked once and it currently doesn't recognize any input. I have re-installed software and tried several USB -Controller cables. Any Advice would be welcome.
