				Weird helicopter twitch - SOLVED
				Posted: 17 Jan 2015 21:00
				by EricM_SoCal
I am still testing out the demo and I have only one problem that is preventing me from purchasing a license.  I am using windows 7 64-bit, Hooshion® USB Flight Simulator FMS Cable for RC Helicopter Airplane Remote Controller, and a Spektrum DX6i.
I calibrated my controller through the controller configuration and have no jumping on the bars showing the realtime controller input.  I am using 5 ch mode and ignoring DR/Expo and throttle/pitch curves.
Here's the issue, I am getting a weird twitch that throws the helicopter out of whack.  I've attached a .fly file, if someone could take a look and let me know if there is a way to fix it that would be great.  I am only touching the stick enough to hover and you will see that both sticks displayed on the screen move to the lower right quickly.
Best regards,
Eric
				Re: Weird helicopter twitch
				Posted: 18 Jan 2015 00:43
as a first step, please:
1. Choose a setting for airplanes on the spectrum, not a heli mode
2. Do a calibration in the windows system settings
3. After that calibrate new in HELI-X
				Posted: 18 Jan 2015 02:42
				by EricM_SoCal
				Hi Michael,
Thank you for your quick reply!  I tried your instructions.
When I calibrate the transmitter in windows with the airplane mode I don't get full range on the collective channel so when I recalibrate Heli-x and then switch to my SimHeli idle up doesn't work.  I get full range on the engine speed but the collective only goes from -70 to 0 with my pitch curve set as 10, 30, 50, 70, 90.
So I tried to recalibrate the transmitter in windows with Heli mode.  This allowed me to get full range on collective and engines(none of the other axis are a problem in either scenario) but I am still getting that weird twitch you saw in the video I attached.
I was reading in the HeliFreak forum that people thought this was only a problem on the DX6i after version 4.2 was released.  If you need me to dig in to any files for you I'd be happy to help, I really want this to work.
Thank you,
Eric
				Posted: 18 Jan 2015 11:51
do you get similar problems when you are using 4 channels instead of five?
				Posted: 18 Jan 2015 14:40
				by EricM_SoCal
				Yes,  I even tried adding a small dead band and it is still happening.
				Posted: 21 Jan 2015 13:26
				by EricM_SoCal
				Any other ideas on this?
				Posted: 21 Jan 2015 15:23
				by JS1
				Just guessing but maybe worth to check:
- Rarely seen static discharge issues causing twich. Check if the cable is rubbing over a surface back and forth when you use the transmitter (once saw this happening when rubbing over a textile covered mouse pad) - or if you charge by scratching your feet on a carpet. Grounding by touching a radiator or so could help.
- Cable/connectors could have a damage. check for squeezes or sharp bends. Also check if moving the cable/plugs affects the twitch - e.g. by idle up the heli and leave it on the ground, first don't touch the transmitter or cable, then only move/bend/stretch the cable and turn the plugs but don't move the radio itself (especially the sticks).
				Posted: 23 Jan 2015 01:05
				by EricM_SoCal
				Thank you JS1,  I was doing more research and some people seem to think that the trainer port on the dx6i is noisy and that is causing the issues.  Maybe a wireless connection might be better for this radio.
				Posted: 23 Jan 2015 08:47
				by JS1
				wouldn't a wireless adapter be plugged into the same trainer port?
				Posted: 23 Jan 2015 18:16
				by EricM_SoCal
				No,  after a little research I found a couple spektrum compatible receivers that output a PPM signal.  This can be soldered to the USB dongle input signal and control the simulator.   I haven't tested it yet but am ordering a orangerx 6 channel receiver with CPPM output.  I will post these results here.
