These well designed helis deserve a place. If you need any parameters, photos, or whatever, please ask.
http://www.jramericas.com/233816/JRP988337/
http://www.jramericas.com/234040/JRP988343/?pcat=1#
JR Forza 450, 450EX and 700?
Re: JR Forza 450, 450EX and 700?
Nice helis indeed. Rumour has it, the 700 is currently being modelled for HELI-X
Not by me but I think it will be very detailed and super clean! Could take a while though. Let's see...
Thanks for the offer to support. I'll forward it, could become very helpful.
The 450 may be following at a later stage.
Nice!
Parts quality and pricing is excellent, not as low as the many Trex450 clones, but very reasonable. I think this will be a good seller. The 450 also has a factory tail cover available, as well as many different colored parts.
There is a 3 blade rotor heads from JR for this one too .
http://www.jrpropo.co.jp/english/produc ... ?hen=84050
The Forza450 has a 6mm main shaft, and can be fitted with 360mm blades, it would be cool if the sim-model would also allow changing the blades, and motor. Reasonable 930W motors exist.
Maybe I missed where this can be set up?
Will the sim also account for battery characteristics, discharge curve etc?
Luckily the batteries in the sim don't discharge
. Different blades, motors, batteries would either require a second model with according flight characteristics (like the 3S and 6S versions of the 450L) - or adjusted parameters in your own XML to match your specific setup.
Forza 450 also is a available with three blades.
JR PROPO Forza 450 mit 3 Blatt-Rotorkopf
