I configure the joystick. As soon as I select an airport the program shuts down and closes. What can I be doing wrong?
thanks
Lee
						Program won't run
Re: Program won't run
Hi Lee,
could you give us some more information, like hardware+OS you're running and what the console window says which launches Heli-X? Also, there's a file named "log.txt" in the files/ directory of the Heli-X dir. Open that, copy and paste the contents here, and we can try to figure out what's wrong.
I have Java version 1.6.0_03-b05 on a 1.8GHz machine with 512Mb ram. My video card has 64Mb instead of the 128Mb recommended but I upped the memory allocation in BIOS so it should run even if slow. I have XP SP2. One window is a system32 command window and the other says HELI-X 0.9.591 --- FPS: 38
The log file is;
Application started
3D Environment created
Found 330 display modes
Using display mode 800x600x32x60
Scenegraph created
Listener Volume: 1.0
Listener Volume: 0.8
Sound configuration read
View initialized
Environment initialized
Loading: net.java.games.input.DirectAndRawInputEnvironmentPlugin
Stick found: Name: PPM
Using Stick PPM
Digital component found:Button 0
Digital component found:Button 1
Digital component found:Button 2
Analog component found:Y Rotation
Analog component found:X Rotation
Analog component found:Z Axis
Analog component found:Y Axis
Analog component found:X Axis
Controller configuration file found: files/controller/PPM.xml
Trying to open xml File files/controller/PPM.xml
Controller configuration file files/controller/PPM.xml read
Visible set true
Keyboard and mouse registered
Trying to open xml File E:\downloads\temp\HELI-X\files\controller\PPM.xml
Pause
Resume
Pause
Trying to open xml File ressources/environments/SkyBox/Altach/Altach.xml
Environment loaded
Resume
Lee
The log file is;
Application started
Scenegraph created
View initialized
Using Stick PPM
Visible set true
Pause
Resume
Pause
Environment loaded
Resume
Lee
Hello Lee,
I see two pssible problems:
1. OpenGL incompatibility,
2. too less memory abailable.
In order to look for 2:
Please delete the file ./files/Application/ApplicationSettings.xml and start HELI-X. Then select the airport "small" (which needs only some bytes of memory). Does HELI-X work now?
To look for the second possibility: Please run the program not by a double click but from the console: start->run->cmd. Then change the directory to your HELI-X directory and type in the name of the .bat file. Now we can see all exception in the console. What can you read there?
I deleted the applicationsettings.xml and selected airport small and got the same results. I then ran it from a command line without restoring the file and here is the last part of the output;
.jar
E:\downloads\temp\HELI-X>set jars=./libs/HeliX/HeliX591.jar;./libs/gluegen/glueg
en-rt.jar;./libs/jagatoo/jagatoo.jar;./libs/hial/hial.jar;./libs/jama/Jama-1.0.2
.jar;./libs/javagamenetworking/javagamenetworking.jar;./libs/jdom/jdom.jar;./lib
s/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinput
.jar;./libs/math/openmali.jar
.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar
E:\downloads\temp\HELI-X>Java\jre1.6.0_03\bin\java.exe -Dsun.java2d.noddraw=true
-Djava.library.path=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-i5
86;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586 -
Xmx256m -classpath ./libs/HeliX/HeliX591.jar;./libs/gluegen/gluegen-rt.jar;./li
bs/jagatoo/jagatoo.jar;./libs/hial/hial.jar;./libs/jama/Jama-1.0.2.jar;./libs/ja
vagamenetworking/javagamenetworking.jar;./libs/jdom/jdom.jar;./libs/joal/joal.ja
r;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinput.jar;./libs/ma
th/openmali.jar;./libs/xith/xith3d.jar ch.ntb.HeliX.application.Application 1>f
iles\log.txt
javax.media.opengl.GLException: Method "glClientActiveTexture" not available
at com.sun.opengl.impl.GLImpl.glClientActiveTexture(GLImpl.java:992)
at org.xith3d.render.jsr231.TextureShaderPeer.clutchTextureUnit(TextureS
haderPeer.java:459)
at org.xith3d.render.jsr231.TextureShaderPeer.shade(TextureShaderPeer.ja
va:733)
at org.xith3d.render.RenderPeer.setState(RenderPeer.java:291)
at org.xith3d.render.RenderPeer.renderAtom(RenderPeer.java:333)
at org.xith3d.render.jsr231.RenderPeerImpl.drawBin(RenderPeerImpl.java:3
74)
at org.xith3d.render.jsr231.RenderPeerImpl.renderMain(RenderPeerImpl.jav
a:628)
at org.xith3d.render.jsr231.RenderPeerImpl.renderRenderPass(RenderPeerIm
pl.java:760)
at org.xith3d.render.jsr231.RenderPeerImpl.render(RenderPeerImpl.java:84
4)
at org.xith3d.render.jsr231.CanvasPeerImplBase.doRender(CanvasPeerImplBa
se.java:306)
at org.xith3d.render.jsr231.CanvasPeerImplAWT.display(CanvasPeerImplAWT.
java:570)
at com.sun.opengl.impl.GLDrawableHelper.display(GLDrawableHelper.java:78
at javax.media.opengl.GLCanvas$DisplayAction.run(GLCanvas.java:435)
at com.sun.opengl.impl.GLDrawableHelper.invokeGL(GLDrawableHelper.java:1
94)
at javax.media.opengl.GLCanvas$DisplayOnEventDispatchThreadAction.run(GL
Canvas.java:452)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
thanks
Lee
.jar
iles\log.txt
haderPeer.java:459)
va:733)
74)
a:628)
pl.java:760)
4)
se.java:306)
java:570)
94)
Canvas.java:452)
thanks
Lee
OpenGL-Driver does not support Ver 1.3. Install better driver for the graphics card.
That's right. What kind of grahics adapater do you have?
New drivers for my video card solved the problem.
thanks much
Lee
						thanks much
Lee
