I'm very interested in Heli-X, but I would like to try it first. I've downloaded the latest demo (vers. 6.0.1614) but it doesn't seem to work with SmartPropoPlus (Spp4). I keep getting the same error : 'No controller found'.
SmartPropoPlus is working perfectly with PicaSim.
What can I do?
Thank you.
Console error :
C:\HELI-X6>Java\jre8\bin\java.exe -Djava.library.path=. -Xms512m -classpath ./l
ibs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/
jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs
/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./lib
s/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/eventbus.jar;./libs/
jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpu
ll-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput-b29.jar;./libs/jdom/jdom.jar;.
/libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.
jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./libs/jme/styles.zip
;./libs/jme/nifty-default-controls.jar;./libs/jme/nifty-style-black.jar HELIX
java.lang.NullPointerException
at net.java.games.input.RawMouse$Button.<init>(RawMouse.java:197)
at net.java.games.input.RawMouseInfo.createControllerFromDevice(RawMouse
Info.java:83)
at net.java.games.input.RawInputEnvironmentPlugin.createControllersFromD
evices(RawInputEnvironmentPlugin.java:160)
at net.java.games.input.RawInputEnvironmentPlugin.enumControllers(RawInp
utEnvironmentPlugin.java:176)
at net.java.games.input.RawInputEnvironmentPlugin.<init>(RawInputEnviron
mentPlugin.java:123)
at net.java.games.input.DirectAndRawInputEnvironmentPlugin.<init>(Direct
AndRawInputEnvironmentPlugin.java:46)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct
orAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC
onstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
at java.lang.Class.newInstance(Class.java:438)
at net.java.games.input.DefaultControllerEnvironment.getControllers(Defa
ultControllerEnvironment.java:160)
at net.HeliX.p.b.r(Unknown Source)
at net.HeliX.p.b.<init>(Unknown Source)
at net.HeliX.j.b.ae(Unknown Source)
at net.HeliX.j.b.<init>(Unknown Source)
at net.HeliX.d.ay.<init>(Unknown Source)
at net.HeliX.d.j.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:749)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:702)
at java.awt.EventQueue$3.run(EventQueue.java:696)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDo
main.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:719)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThre
ad.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.
java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
ad.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
SmartPropoPlus
Anatole76be
Re: SmartPropoPlus
Problem solved !
Apparently Heli-x is not compatible with Corsair Gaming Mouse RGB 65 (or the Corsair Utility)
