Update of the Garage Airport
there is an update of the Garage Airport available. If you have problems with the performance, give it a try.
toomuchcookies
Re: Update of the Garage Airport
Post by toomuchcookies »
I am running version 2015-3-7 ( ) of the Garage airport, but heli-x keeps telling me,
"Underground_Garage: Object is not available
Please update from the HELI-X server."
I then can update the airport, but the error message keeps popping up.
Hello
I cannot reproduce this. Do others have this probem?
Post by ThomasC »
Michael wrote:Hello
Here absolutely no problem, cannot confirm
Mgfiest
Post by Mgfiest »
I had no problem updating from the server. It installed with no issue
toomuchcookies
Is there any log file i could look into? Otherwise i guess the next step would be to download the files again?
By the way i am running heli-x under linux.
toomuchcookies
ok, i just found the problem:
In the file Underground_Garage.xml the file names with _Box_ in them do not correspond to the file names in the path. At least not if the system is looking for case sensitive file names.
So, i changed the path-parameters where i could find a "Box" into "box" and now it seems to work.
For example:
   <Object FrictionFactor="0.5" MakeCrashObject="true">
      <Path> AWall_Box_mx.obj </Path>
      <Translation> 12,0,-4 </Translation>
      <Rotation> 0 </Rotation>
      <ShadowCaster> false </ShadowCaster>
      <ShadowReceiver>true </ShadowReceiver>
   </Object>
into
   </Object>
I guess, you would want to update that file, otherwise linux and mac users will have a problem with it.
tino227
Post by tino227 »
toomuchcookies wrote: .., i changed the path-parameters where i could find a "Box" into "box" ...
thank you!
That was it!
Yes, thanks. The download is corrected.
