I hope someone can point me in the right direction. I started my registered version of Heli-x this morning and the black command window shows up then the statistics window shows up but the main window with the heli and airfield won't show up. I've tried alt-tab, and selecting it from the tool bar and it won't show. The only thing I've changed is the heli and airfield since registering. Any Ideas?
Thank you!
Main window not showing
Re: Main window not showing
Hello
please bring the program with the menu simulation->Factory settings in the factory settings and try again.
EricM_SoCal
Hi Michael,
I can't since that is the screen that is not showing on my desktop.
Eric
Eric
@Eric: does the window show up in your taskbar? In case yes: sometimes Windows has problems when Window gets out of screen borders. I experience this kind of problem with many applications (-> not a Heli-X problem), and sometimes have to experiment to get my window on screen again. Unfortunately, the ALT-Space key combination is not functional in Heli-X to open the move/resize/restore context menu. Please try to rename your files\Application\ApplicationSettings.xml to something like ApplicationSettings.xml.old and see if this solves your problem (this resets your Heli-X, you'll have to choose language again, registration is not affected)
Have success
Have success
EricM_SoCal
That worked, Thank you!
Eric
Eric
