Is it possible to mix gas and pitch in Heli-5 ?
Thanks for your help.
Regards
Mixing gas and pitch
Re: Mixing gas and pitch
There is both throttle and pitch curves in Heli-X to control both accordingly.
Ok I will try to see where this parameter is. If you can tell me where you have it can be good also.
Thanks
Thanks
Just check the menu. It's right there under "Flight modes". If you are not used to this kind of curves, there's a ton of good reads in the internet for CP helis. It will work exactly the same with any decent transmitter to control a real CP model's throttle and pitch.
