I'm having a similar problem, running the latest version of Linux Mint Debian Edition (64bit) and HELI-X. I'm using a wireless XBox 360 controller, which is working fine in jtest (and in other games).
It seems to be recognised, though the plugin claims to have 12 controllers... -
./runHELI-X64.sh
Set new path for the resources: /home/ben/Downloads/HELI-X41/resources/
Set new path for the user files: /home/ben/Downloads/HELI-X41/files/
Couldn't find tag "Resolution" in file "/home/ben/Downloads/HELI-X41/files/Application/ViewSettings.xml"
Found 5 display modes
17-Nov-2012 20:32:37 net.java.games.input.ControllerEnvironment log
INFO: Linux plugin claims to have found 12 controllers
Controller found: Name: Generic X-Box pad(Generic X-Box pad)
Controller found: Name: Generic X-Box pad(Generic X-Box padX)
Controller found: Name: Generic X-Box pad(Generic X-Box padXX)
Controller found: Name: Generic X-Box pad(Generic X-Box padXXX)
Using Stick Generic X-Box pad
Digital component found:A
Digital component found:B
Digital component found:X
Digital component found:Y
Digital component found:Left Thumb
Digital component found:Right Thumb
Digital component found:Select
Digital component found:Unknown
Digital component found:Mode
Digital component found:Left Thumb 3
Digital component found:Right Thumb 3
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
Analog component found:rz
Digital component found:pov
Controller configuration file found: /home/ben/Downloads/HELI-X41/files/controller/GenericX-Boxpad.xml
Controller configuration file /home/ben/Downloads/HELI-X41/files/controller/GenericX-Boxpad.xml read
ben@comatus:~/Downloads/HELI-X41$ ./runHELI-X64.sh
17-Nov-2012 20:42:55 net.java.games.input.ControllerEnvironment log
Exception occurred during event dispatching:
java.lang.NullPointerException
at a.a.a.c.c.k.a(Unknown Source)
at a.a.a.c.c.c.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2012)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2335)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:404)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6268)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6033)
at java.awt.Container.processEvent(Container.java:2045)
at java.awt.Component.dispatchEventImpl(Component.java:4629)
at java.awt.Container.dispatchEventImpl(Container.java:2103)
at java.awt.Component.dispatchEvent(Component.java:4455)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4633)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4297)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4227)
at java.awt.Container.dispatchEventImpl(Container.java:2089)
at java.awt.Window.dispatchEventImpl(Window.java:2517)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:649)
at java.awt.EventQueue.access$000(EventQueue.java:96)
at java.awt.EventQueue$1.run(EventQueue.java:608)
at java.awt.EventQueue$1.run(EventQueue.java:606)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:105)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:116)
at java.awt.EventQueue$2.run(EventQueue.java:622)
at java.awt.EventQueue$2.run(EventQueue.java:620)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:619)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:275)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:194)
at java.awt.Dialog$1.run(Dialog.java:1072)
at java.awt.Dialog$3.run(Dialog.java:1126)
at java.awt.Dialog.show(Dialog.java:1124)
at java.awt.Component.show(Component.java:1551)
at java.awt.Component.setVisible(Component.java:1503)
at java.awt.Window.setVisible(Window.java:881)
at java.awt.Dialog.setVisible(Dialog.java:1011)
at a.a.a.c.c.c.a(Unknown Source)
at a.a.a.c.c.c.<init>(Unknown Source)
at a.a.a.c.c.k.actionPerformed(Unknown Source)
at a.a.a.c.c.k.<init>(Unknown Source)
at a.a.a.m.q.<init>(Unknown Source)
at a.a.a.m.e.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:226)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:647)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:617)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)
... but then when trying to configure the controls nothing happens. I updated to the latest version of jinput but I think it is just the same as the version in the HELI-X download.
Also, sorry to be such a total novice, but I'm planning to use this to learn how to fly a quadcopter and the configuration settings are aimed at collective pitch helicopters - which stick should I set as which to get a Mode II setup?
Thanks,
Ben
(PS. There aren't many Linux flight sims that do quadrotors, you should advertise it more as such.)
Ben
