I'm having some trouble running heli-x on linux with any type of usb joystick. I get a "no controller found" error. The KDE joystick panel seems to detect the joysticks well (/dev/input/js0, I've even tested doing a chmod ugo=rwx /dev/input/js0, and it still gives a "no controller found" error), and I can see that the axes move correctly, so the hardware works. The log file from heli-x says;
Application started
3D Environment created
Using openGLLayer JOGL_AWT
Found 11 display modes
Trying to open xml File files/Application/ViewSettings.xml
Using display mode 1024x768x?x?
Scenegraph created
Listener Volume: 1.0
Trying to open xml File files/Application/SoundSettings.xml
Listener Volume: 0.8
Sound configuration read
Trying to open xml File files/Application/CameraSettings.xml
View initialized
Trying to open xml File files/Application/EnvironmentSettings.xml
Environment initialized
Loading: net.java.games.input.LinuxEnvironmentPlugin
Failed to open device (/dev/input/event6): Failed to open device /dev/input/event6 (13)
Failed to open device (/dev/input/event4): Failed to open device /dev/input/event4 (13)
Failed to open device (/dev/input/event2): Failed to open device /dev/input/event2 (13)
No Joystick found
Trying to open xml File files/Application/ApplicationSettings.xml
Visible set true
Keyboard and mouse registered
Application successfully initialized
Stopping HELI-X
hydra@hydra-zeus:~/Desktop/HELI-X$ ./runHELI-X.sh
java.lang.UnsatisfiedLinkError: net.java.games.input.LinuxJoystickDevice.nGetAxisMap(J)[B
        at net.java.games.input.LinuxJoystickDevice.nGetAxisMap(Native Method)
        at net.java.games.input.LinuxJoystickDevice.getDeviceAxisMap(LinuxJoystickDevice.java:200)
        at net.java.games.input.LinuxJoystickDevice.<init>(LinuxJoystickDevice.java:70)
        at net.java.games.input.LinuxEnvironmentPlugin.enumerateJoystickControllers(LinuxEnvironmentPlugin.java:406)
        at net.java.games.input.LinuxEnvironmentPlugin.enumerateControllers(LinuxEnvironmentPlugin.java:233)
        at net.java.games.input.LinuxEnvironmentPlugin.<init>(LinuxEnvironmentPlugin.java:113)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
        at java.lang.Class.newInstance0(Class.java:355)
        at java.lang.Class.newInstance(Class.java:308)
        at net.java.games.input.DefaultControllerEnvironment.getControllers(DefaultControllerEnvironment.java:157)
        at ch.ntb.HeliX.controller.FlightController.<init>(FlightController.java:86)
        at ch.ntb.HeliX.simulation.Simulation.initController(Simulation.java:164)
        at ch.ntb.HeliX.application.Application.<init>(Application.java:153)
        at ch.ntb.HeliX.application.Application$1.run(Application.java:757)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
If anyone has any ideas I'd be much obliged.
(Unfortunately my german is not very good, so I would prefer english replies if possible).
