Sun Java 8
Posted: 13 Jan 2016 16:35
by n8xyn
I had to reinstall my Linux system after a year of good service (thanks to my misconfiguration). In doing so I also decided to use the latest Java 8 instead of 7. Well now when I launch Heli-X it keeps spawning itself over and over again rendering it useless and nearly locking up the 8 core computer. Since Java 7 is now at end of life will there be a new release of Heli-X for Java 8? I've attached the error message.
jim@jim-linux:~/HELI-X6 > sh runHELI-X.sh
Java HotSpot(TM) 64-Bit Server VM warning: You have loaded library /home/jim/HELI-X6/libjinput-linux.so which might have disabled stack guard. The VM will try to fix the stack guard now.
Edit: I took the advice of the OS "It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'." and it seems OK at this point, I'm still interested in a future version that likes Java 8 :-)
