Heli-x on Windows 10
cvs
Post by cvs » 10 Jun 2015 08:47
Anybody has Heli-x running on Windows 10 (64bit) ?
It doesn't seem to continue after the language selection.
Thanks
Best regards
Christophe
Re: Heli-x on Windows 10
Post by Michael » 10 Jun 2015 21:00
It is likely that you do not have the correct driver for your graphics adapter. Download it from the vendor's web site.
Any output in the console window?
cvs
Post by cvs » 11 Jun 2015 11:45
Because of older graphic card, V6 is not working. V4 works.
Thanks
Best regards
Christophe
eXhaLe
Post by eXhaLe » 13 Sep 2015 16:16
Same problem here. After updating to Windows 10, Heli-X V6 doesn't work any longer. I reinstalled Heli-X, Java and the display driver for Geeforce 310M aswell but it didn't fix the issue. After selecting the language, the console window closes.
On Windows 7 everything was fine.
Post by Michael » 13 Sep 2015 21:52
You need to find a graphics driver supporting openGL.
RolfHeller
Post by RolfHeller » 06 Nov 2015 11:41
i 'd like to use Heli-X V6 in a Windows 10 64k-environment. I' m getting the following answer, when starting heli-x from the command-line:
C:\HELI-X6>Java\jre8\bin\java.exe -Djava.library.path=. -Xms512m -classpath ./libs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jme/nifty-style-black.jar HELIX
handleError
SCHWERWIEGEND b 12:24:03 Failed to create display
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at com.jme3.system.lwjgl.LwjglDisplay.createContext(LwjglDisplay.java:140)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.initInThread(LwjglAbstractDisplay.java:113)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:207)
C:\HELI-X6>rem If you want to configure the proxy server manually, use this:
C:\HELI-X6>rem Java\jre8\bin\java.exe -Dsun.java2d.noddraw=true -Dhttp.proxyHost=<PROXY_NAME_OR_IP> -Dhttp.proxyPort=<PROXY_PORT> -Djava.library.path=. -Xms512m -classpath ./libs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-
and the following message is displayed:
Failed to create Display
Does it show that OpenGL is lacking?
The graphics-card from "ATI Radeon HD 4600 Series" is run with an actual Microsoft PNP-Monitor (Standard)-driver. The monitor is HannsG HW191D.
Any idears?
Glück auf!
Rolf
RolfHeller
Post by RolfHeller » 19 Dec 2015 18:49
Hey,
I inplemented a new graphics card and Heli-x starts.
Rolf
Glück auf!
Rolf
