Activation hanging Windows 7 64 bit
helimike
Post by helimike » 21 Oct 2014 14:32
I am trying to activate my newly purchased code. The software is hanging on activate full version screen and the cmd screen as well. the last lne the command screen says:
C:\HELI-X5>set libPath=.
C:\HELI-X5>set jars=./libs/HeliX/HeliX5.jar
C:\HELI-X5>set jars=./libs/HeliX/HeliX5.jar;./libs/jme/jME3-core.jar
C:\HELI-X5>set jars=./libs/HeliX/HeliX5.jar;./libs/jme/jME3-core.jar;./libs/jme/
jME3-plugins.jar
jME3-plugins.jar;./libs/jme/jME3-terrain.jar
jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar
jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/
jme/jME3-blender.jar
jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar
jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar
jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/j
me/eventbus.jar
me/eventbus.jar;./libs/jme/lwjgl.jar
me/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar
me/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftyg
ui.jar
ui.jar;./libs/jme/xmlpull-xpp3.jar
ui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar
ui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar
ui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./l
ibs/jdom/jdom.jar
ibs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar
ibs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar
ibs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./l
ibs/jme/gluegen-rt.jar
ibs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar
ibs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar
ibs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./
libs/jme/styles.zip
libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar
libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jme/nifty-style
-black.jar
C:\HELI-X5>Java\jre7\bin\java.exe -Djava.library.path=. -Xms512m -classpath ./l
ibs/HeliX/HeliX5.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs
/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./
libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/eventbus.jar;./libs/
jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpu
ll-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs/jdom/jdom.jar;./lib
s/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.jar;
./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./libs/jme/styles.zip;./l
ibs/jme/nifty-default-controls.jar;./libs/jme/nifty-style-black.jar HELIX
Set new path for the resources: C:/HELI-X5/resources/
Set new path for the user files: C:/HELI-X5/files/
Directory C:/HELI-X5/resources/Translation/ created
Directory C:/HELI-X5/files/Application/ created
Directory C:/HELI-X5/files/controller/ created
Directory C:/HELI-X5/files/screenshots/ created
Directory C:/HELI-X5/files/Server/ created
Directory C:/HELI-X5/files/lists/ created
Couldn't find tag "WindowSettings" in file "C:/HELI-X5/files/Application/Applica
tionSettings.xml"
Couldn't find tag "InfoWindow" in file "C:/HELI-X5/files/Application/Application
Settings.xml"
Couldn't find tag "ChatWindow" in file "C:/HELI-X5/files/Application/Application
Settings.xml"
Controller found: Name: KDSMODEL Simulator - XTR+G2+FMS Controller(KDSMODEL Simu
lator - XTR+G2+FMS Controller)
Using Stick KDSMODEL Simulator - XTR+G2+FMS Controller
Analog component found:Rudder
Analog component found:Throttle
Analog component found:Slider
Analog component found:Z Axis
Analog component found:Y Axis
Analog component found:X Axis
Digital component found:Button 3
Controller configuration file not found: C:/HELI-X5/files/controller/KDSMODELSim
ulator-XTRG2FMSController.xml
Controller configuration file found: C:/HELI-X5/files/controller/KDSMODELSimulat
Controller configuration file C:/HELI-X5/files/controller/KDSMODELSimulator-XTRG
2FMSController.xml read
I'm on a i7-2600 16gb ram, nvida gtx 560 2gb
Not working for me. So far im not impressed with my purchase as it took 3 days to get the code and now it does not work.
