Java 11 Error on Ubuntu 19.10
You findings in V9. Don't forget to mention the revision number and your operating system, when appropriate.
birnenkind
Post by birnenkind »
Hi Folks,
Im using ubuntu 19.10 with up2date Java Version:
HELI-X9c$ java --version
openjdk 11.0.6 2020-01-14
OpenJDK Runtime Environment (build 11.0.6+10-post-Ubuntu-1ubuntu119.10.1)
OpenJDK 64-Bit Server VM (build 11.0.6+10-post-Ubuntu-1ubuntu119.10.1, mixed mode, sharing)
5.3.0-42-generic #34-Ubuntu SMP Fri Feb 28 05:49:40 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
I removed "-XX:+CMSIncrementalMode" from runHELIX-X.sh --> without removing i'll get unrecognized CMSIncrementalMode"
I'll get:
sudo ./runHELI-X.sh
OpenJDK 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
OpenJDK 64-Bit Server VM warning: You have loaded library /home/penne/Downloads/HELI-X9c/libjinput-linux.so which might have disabled stack guard. The VM will try to fix the stack guard now.
Linux plugin claims to have found 7 controllers
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.jme3.util.ReflectionAllocator (file:/home/penne/Downloads/HELI-X9c/libs/jme/jme3-core.jar) to method sun.nio.ch.DirectBuffer.cleaner()
WARNING: Please consider reporting this to the maintainers of com.jme3.util.ReflectionAllocator
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/sun/xml/internal/messaging/saaj/util/ByteInputStream
	at net.HeliX.t.d.l_(Unknown Source)
	at net.HeliX.t.e.b.l_(Unknown Source)
	at net.HeliX.t.e.b.<init>(Unknown Source)
	at com.a.a.a.a.a(Unknown Source)
	at net.HeliX.v.o.D(Unknown Source)
	at net.HeliX.c.a.<init>(Unknown Source)
	at net.HeliX.c.c.run(Unknown Source)
	at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
	at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
	at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.ClassNotFoundException: com.sun.xml.internal.messaging.saaj.util.ByteInputStream
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
	... 20 more
Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `version->filename == NULL || ! _dl_name_match_p (version->filename, map)' failed!
is my mod of runHELI-X.sh and the up2date Version of Java my Problem?
greets
Re: Java 11 Error on Ubuntu 19.10
I thought this error has gone in V9 ....
Please use OpenJDK 8
birnenkind
java -version
openjdk version "1.8.0_242"
with this version it's fine...
