9.0.75 Locking Up
You findings in V9. Don't forget to mention the revision number and your operating system, when appropriate.
danieldh206
9.0.75 Locking Up
Post by danieldh206 »
Windows 10 Professional
9.0.75
SIM stopped working after updated to 9.0.75. This is the output from the CMD window.
java.lang.ArrayIndexOutOfBoundsException: 2147483647
at net.HeliX.q.c.a(Unknown Source)
at net.HeliX.t.e.b.a(Unknown Source)
at net.HeliX.t.e.b(Unknown Source)
at net.HeliX.d.ad.a(Unknown Source)
at net.HeliX.v.o.a(Unknown Source)
at net.HeliX.v.i.update(Unknown Source)
at net.HeliX.v.o.update(Unknown Source)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.runLoop(LwjglAbstractDisplay.java:151)
at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:197)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:232)
I had no issues with SIM on 9.0.73
Thank you,
Daniel
danieldh206
Re: 9.0.75 Locking Up
I rebooted computer and same issue of locking up happens.
Thank you,
Daniel
danieldh206
The SIM is not actually locking up. If I turn on Autorotation the screen freezes, if I turn off the motor with idle up 1 or 2 the screen freezes. I say the screen freeze because nothing happens on the screen, but when I turn autoration off or turn the motor back on with idle up 1 or 2 and the helicopter has not crashed yet it will have flown away. Also the Protos 700 H will not load.
I am running the a Geforce GTX 1660 TI with drivers 441.87 on Windows 10 Pro 1903
Daniel
danieldh206
Re: 9.0.75 Locking Up FIXed in 9.0.79
It was only a short quick test but everything is working again in 9.0.79 and the Protos 700H has the best sound so far.
Thanks. There was a problem inside. Please update to 2080 ...
