1912 - Release Candidate
Post by Michael » 24 Feb 2019 12:25
you may update to 1912
New:
AR flight mdoe will stop the engine of a plane
filter in model selection corrected
Bug fixes in the nitro/electric engine
Thank you for your feedback.
earlgrey
Re: 1912 - Release Candidate
Post by earlgrey » 24 Feb 2019 14:17
Extra 330: Seitenruder Wirkung müsste ca 20% mehr sein. Höhenruder wirkt monstermässig, so dass Rückentrudeln sehr einfach ist (zu einfach für meinen Geschmack ). Aber Messerflug Looping ist im Vergleich dazu viel zu schwierig.
Piper: Verhalten im Torque Training ist unrealistisch, sie geht trotz Vollgas nicht vom Boden weg aber bleibt troztdem senkrecht ohne abzukippen
Trojan: Verhalten im Torque Training ist unrealistisch, sie lässt sich viel zu leicht halten und müsste eigentlich nach kurzer Zeit abkippen
Brian
Post by Brian » 24 Feb 2019 21:30
Open issues from 1906:
DassaultMystere:
2000 rev/min. when turbine idle is too low.
FK 12 Comet:
Max climb rate of 20m/s (2019-02-24) too high.
Tortuga Update:
Available version 2019-02-11
Installed version 2019-02-20
Was version downgrade your intention?
Brian
Post by Brian » 24 Feb 2019 21:39
earlgrey wrote:
24 Feb 2019 14:17
You can do Torque Training only with models, having enough power to provide a positive climb rate in this flight mode (this is realistic).
Trojan: Engine does not provide enough power. It's very hard for me to do keep the model upright.
Brian
Post by Brian » 24 Feb 2019 23:52
Extra 330XL (2019-02-25):
Air resistance too high. Try switch engine off and do emergency landing.
Compare against Trojan or Extra300, they have good gliding performance.
earlgrey
Post by earlgrey » 25 Feb 2019 21:31
Of course enough power is needed for torque training. What I meant is that some models keep standing upright on the ground when the initial height is low, say 1m or 2m.
Post by Michael » 26 Feb 2019 22:37
Several models revised. Please update the models.
earlgrey
Post by earlgrey » 27 Feb 2019 22:18
much better now
Brian
Post by Brian » 27 Feb 2019 23:17
Air resistance of Extra 330XL is better now.
Air resistance of Extra 330 can be reduced, too.
EasyStar_Aileron better now.
Brian
Post by Brian » 02 Mar 2019 14:54
I've just downloaded the release version V8.0.1912 for Linux from the homepage, unpacked the tar.gz archive, and started the shell script as usual, but this version does not work
carsten@Napoleon:~/Programme/HELI-X8$ ./runHELI-X.sh
handleError
SCHWERWIEGEND o 14:46:33 Uncaught exception thrown in Thread[jME3 Main,6,main]
com.jme3.asset.AssetLoadException: An exception has occured while loading asset: PMincho_04.png (Flipped)
at com.jme3.asset.DesktopAssetManager.loadLocatedAsset(DesktopAssetManager.java:261)
at com.jme3.asset.DesktopAssetManager.loadAsset(DesktopAssetManager.java:373)
at com.jme3.asset.DesktopAssetManager.loadTexture(DesktopAssetManager.java:390)
at com.jme3.font.plugins.BitmapFontLoader.load(BitmapFontLoader.java:103)
at com.jme3.font.plugins.BitmapFontLoader.load(BitmapFontLoader.java:170)
at com.jme3.asset.DesktopAssetManager.loadLocatedAsset(DesktopAssetManager.java:259)
at com.jme3.asset.DesktopAssetManager.loadFont(DesktopAssetManager.java:412)
at net.HeliX.nifty.ld.g(Unknown Source)
at net.HeliX.nifty.ld.a(Unknown Source)
at net.HeliX.c.ay.a(Unknown Source)
at net.HeliX.nifty.li.<init>(Unknown Source)
at net.HeliX.c.ay.c(Unknown Source)
at net.HeliX.c.ag.<init>(Unknown Source)
at net.HeliX.c.ay.<init>(Unknown Source)
at net.HeliX.c.aq.c(Unknown Source)
at net.HeliX.c.aq.<init>(Unknown Source)
at net.HeliX.v.o.initialize(Unknown Source)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.initInThread(LwjglAbstractDisplay.java:130)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:211)
Caused by: javax.imageio.IIOException: Error reading PNG image data
at com.sun.imageio.plugins.png.PNGImageReader.readImage(PNGImageReader.java:1345)
at com.sun.imageio.plugins.png.PNGImageReader.read(PNGImageReader.java:1614)
at javax.imageio.ImageIO.read(ImageIO.java:1448)
at javax.imageio.ImageIO.read(ImageIO.java:1352)
at com.jme3.texture.plugins.AWTLoader.load(AWTLoader.java:179)
at com.jme3.texture.plugins.AWTLoader.load(AWTLoader.java:192)
... 22 more
Caused by: javax.imageio.IIOException: Unknown row filter type (= 255)!
at com.sun.imageio.plugins.png.PNGImageReader.decodePass(PNGImageReader.java:1143)
at com.sun.imageio.plugins.png.PNGImageReader.decodeImage(PNGImageReader.java:1223)
at com.sun.imageio.plugins.png.PNGImageReader.readImage(PNGImageReader.java:1338)
... 28 more
The Beta version runs without any errors.
Any ideas?
Locked
