1900
Locked
Post by Michael » 06 Feb 2019 20:44
you may update to revision 1900. New:
- For those who have no trim switches on the controller there is now the possibility to set trim settings and store them to each model if wished.
- Stick Mover support prepared.
Thank you for your feedback.
Devil
Re: 1900
Post by Devil » 07 Feb 2019 22:58
die 1900 läuft bei mir unter Win 10 mit dem RX2SIM einwandfrei.
Die Trimmung klappt auch, lediglich die Piper hat noch ein falsches Vorschaubild.
LG,Micha
Mike656
Re: 1900
Post by Mike656 » 08 Feb 2019 09:31
Hi Michael
Easy first time install of 1900 yesterday on an i7 MacBook Pro os X with wireless RX2SIM. First install so can’t comment on how it compares to V7, but everything working fine.
Also installed yesterday on a windows 10 gaming laptop, using a 4 switch ksim. Again, easy install but setting up the controller took a little time as at first it wasn’t seeing one of the channels (fine on V7). FPS seems to have jumped from around 220 to 300. No problems found as yet.
Regards
Brian
Re: 1900
Post by Brian » 10 Feb 2019 00:01
1900 runs perfectly under Debian 9 with FeiYing (Mode XTR+G2+FMS), Futaba T14SG, and jinput-b1.jar input system of HELI-X. I noticed a performance increase of the graphics system. I've never seen a frame rate above 100 fps before. Wow!
Trim works fine. You might want to change the description such that it fits for helis as well as for planes. E.g.:
English:
Pitch/Throttle
Nick/Elevator
Roll/Aileron
Rudder
German:
Pitch/Gas
Nick/Höhenruder
Roll/Querruder
Gieren/Seitenruder
Cross-wind sensitivity is much better now.
Extra 300 is a little bit wobbly at ground, if you use the rudder to be on track during take-off. Is this the intended behavior?
In my opinion, Extra 300 needs more wind-resistance.
What do the other testers say?
Re: 1900
Post by Michael » 11 Feb 2019 20:35
Brian wrote:
10 Feb 2019 00:01
There is a complete rework in 1903. Hope it is better now.
Locked
