1854
Locked
please update to Rev 1854 and also the plane models.
Changes to the models (among others):
- Stearman: rudder without engine thrust
- ASW28: airbrakes and gear influence
- Dassault Mystere: a bit faster
- EasyStar: Can fly inverted
- Extra 300: revised to new profiles
Changes in the software:
- Russian language updated
- OpenGL defaults changed
- emergency training with gliders with airbrakes should work now
- handlaunch speed from xml file
- Sound improved (pitch, idle, etc.)
- Friction in the power trains, so the the prop might stop
- less debug output
You reported problems while the download of airports. This could not be reproduced. Please check again.
Kind regards,
Brian
Re: 1854
Post by Brian »
The "Alpha" download link contains rev. 1850 for Linux OS.
Brian
Re: 1854
Post by Brian »
OK. Splash-Screen initially shows 1850, after registration it shows 1854.
Re: 1854
You can choose in the menu
options->Update HELI-X
to switch to the next revision.
Devil
Re: 1854
Post by Devil »
bei
  • EasyStar
  • Edge540v3_FC
  • Opterra
  • Tortuga
sehe ich als Vorschaubild jeweils den Modster in der 1854.
Könnte man vielleicht die Modelle hne Fahrwerk standardmässig per Handstart beginnen ?
Momentan liegen die ja noch auf dem Boden.
LG,Micha
Locked
