I have a DJI Phantom 2 (NON vision) and want to use HELI-X.
Do I need another controller or can i use my DJI controller ? If I can what is the setup process?
I am on a iMac too and when i start the software I don't see a controller installed? Do i need to install it?
DJI Phantom Controller and setup
Re: DJI Phantom Controller and setup
the controller of the DJI does not work. you need another controller...
To spare your original controller from extensive sim training, I'd suggest anyway to have a separate controller for the sim. Either a cheap transmitter with cable or a usb controller like this one ...in case of worn out sticks etc. much easier and cheaper to replace.
